Fuel economy mods?
gt1009
st.charles,IL
In the age of $4 diesel, has anyone done any mods to their cucv to improve fuel economy? The 20mpg stock is pretty good, but any more would be lovely. I was thinking a better air intake and exhaust, but there has to be something else that can be done.
Bobert
9
Des Moines/ Iowa
I wish mine was getting 20 mpg. I am stuck at 16.
I think If you really want an improvement, you need a 700R4. But then you wouldn't have the th400. :(
I tried that power service fuel additive, and it dropped to 13mpg. Won't try that again.
I try not to look at the $$$$ when I fill up. Makes it easier.
Tibby
Riverton,IL
My M1028 has a 700R4. It is something you should consider. As long as you steer clear of the early years and have the transmission gone through thoroughly/properly before you install it. I have 4.10 axle gears, stock tires, and with a LIGHTWEIGHT right foot, I have gotten 17-18 MPG. You might like the 3.06 vs. 2.48 1st gear. 0.70 4th gear won't hurt you either.
AJMBLAZER
Paducah, KY
The OD gear is the obvious one but not the cheapest.
Basically you want to make the engine breath in more, cooler air and exhale out the gases easier. I haven't done anything with my intake yet but I did replace the stock mufflers with Cherry Bombs and it definitely got a bit peppier. Can't tell in the cab if it sounds any different but the "seat of the pants" power increase was easily worth the $60 or so I invested in it.
Croatan_Kid
New Bern, NC
I've got a seriously beefed 700R4 awaiting it's finaly resting place in between the frame rails of my M1008. Even with 39 inch tires, it still needs OD bad! I'm averaging 14 MPG right now as best I can tell with the odometer not reading correctly, which aint bad for some big tires like that and they're pretty heavy. A 700R4 swap aint too hard, you just have to search for certain diesel specfic parts like the torque converter, tall transfer case adapter, and the TV cable bracket for the 6.2/700R4. You'll also need to swap input shafts on the transfer case or just swap in another one.
Try an intake mod and some decent exhaust and see what happens then go from there.
