Fuel filter prime
Hulk5T
12
Texas
I have a m923 a2 with Cummins 8.3 ,I need to change fuel separator and TM is not clear on purging air from it after change .is it the hex head on top of hand pump?
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
Run the motor to operation temperature. Fill your replacement filter with good clean fuel. Swap the filter unit in a timely manner. Pump the primer pump till you hear it pushing fuel thru the injection lines. You will hear the fluid moving. Start it and see if it'll stay running.
If it doesn't pump the primer again till you hear it.
The motor being at operating temp will make it easier to get the air purged out.
Hulk5T
12
Texas
Thank you sir
M35A2-AZ
435
Tonopah, AZ
Also on the back side of the injection pump there is a 10mm bolt that is the bleed port to let the air out as you pump on the primer pump.100_1271-1.JPG
