fuel fired heater
hedelta
Glen Arm, MD
A friend had a fuel fired heater fuel pump go up on him any idea where to just get the pump or do you think a pump from lets say auto zone as long as it is 24 volts. What kind of output dose a standard one put out. Any help would be great.
cranetruck
75
Meadows of Dan, Virginia
Required fuel pressure is 3 to 15 psi. Yes, any 24vdc pump should be fine. My system runs at about 7 psi.
Oh, and the pump capacity is 25gal/hr.
The original pump is serviceable and has a filter built-in, so check that too...
the fuel must be well filtered.
ccequipment
Unionville,IN
While were on the subject of artic heaters, my use with them has only been with diesel fuel only. I have a few kits around and have a small warehouse that I am going to set one up as a display model but use it to heat the buliding. I am only out there for a hour or so each morning. My questions is has anyone played with burning fitered used motor oil and a diesel mix, of should I just stay with diesel. My fuel source would come from a warm building (60 degrees +) all the time so the fuel should be warm, except on start up with left over fuel in the cold building part of the lines.. I am thinking just staying with diesel would be the best, but what do you guys think?
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I've been wondering, since the pumps seem to bring about $50 on ebay, what is the volume and psi of the intake heater pumps for a multi put out? I have several of them that I could use for this.
GoHot229
Some years ago I had a Southwind gas heater, which were widly used in VW's. I needed a igniter for it and searched, this was back in about 1994-95 or so and the Company that messed with them was in Castle Rock Colorado. They also used a specialty fuel pump. It might be that they are still in bussiness and could be contacted and a suitable pump found through them. For those of us with not enough budget for these nice fuel type heaters is there any agreement on which is the best water type heater to use in the Deuce? I keep seeing one in the Boyce Equiptment site, who is big into MV's
