Fuel Gauge Indication Problem
BM59_Fan
Las Vegas New Mexico
The previous owner of my 710K Pinz installed a VDO fuel gauge on the dash. The problem I am seeing is that the gauge is indicating empty at half tank. I do not think the sender was changed. So could the problem be is it is a 12VDC gauge?
Any guesses and what should I look for?
Mike
Las Vegas NM
CliffSegar
Rockwood, TN
At half tank or 1/4 tank?
As a European vehicle, it goes to "R" when there is about 70Km of fuel left. That's their Reserve setting. There is no "Empty" mark.
CliffSegar
Rockwood, TN
Finally got out to look at mine with a volt meter. As you can see, it is just a bit over 1/2 tank and the gauge has 3.18 volts to the sense line.20160513_195556.jpgFuelGage.jpg
Sonarman
Sonoma, Ca
I just installed a VDO guage in mine. There is a small screw on side of guage to adjust it. Use plastic insulated screwdriver. The sending unit should be 0-100 ohms depending on full or empty. That can be checked with multimeter.
