fuel leak
bigbad53m211
petersburg wv
I have a m35a2 and the 12 point screw/bolt that go's under the lines in the top of the injector pump is leaking and I cant get it to stop can anyone help me fix my problem thanks jeff
Floridianson
2,437
Interlachen Fl.
There is no Oring no washer it's a metal to metal fit. Myself I like to take a pair of tin snips and cut off the fireing order injector line order tin cover. Then you can realy see what and where. You might be able to take the plug out and polish it up. Then very carefully polish the head hole but don't get any trash or what not in the hole. This is saying like said all is good and no cracks between injector line ports and center pulg hole.
bigbad53m211
petersburg wv
ok thanks for the input and I am going to replace it cause it is cracked and I will clean it up good befor I put it back together
