kennys@wi.rr.com
- 23
- 38
- Waukesha, WI
Starting late last year my deuce has been acting up when when I'm driving. It will run 55+ all day long but anything slower it acts like it's out of fuel. At Iola we found a crushed copper line under the front cross member and thought that may be part of my problem. I finally got around to replacing the copper line with a rubber line and the secondary filters with a spin on filter. Still the same problem. I had another member take the truck for a ride and of course where we did there was no problem. Then half way home it started doing it again. I determined that when the truck is at operating temp, that's when I have my problem. I have noticed that some problems come in groups, what happens to my truck will soon happen to yours sort of thing. I just replaced the o rings under the HH on toddm's deuce and after that we discovered that his in tank pump was dead. The bottom cover fell off and got stuck frying the pump, not just the fuse. I thought to myself maybe my in tank pump is shot. So I pulled it. My pump is almost new, but so is the hose. Turns out when the motor pool replaced my pump the grabbed regular fuel hose and of course it was melting between the grooves of the hose clamps, and I could leave finger prints in the hose collapsing it real easy. I couldn't do that with Todds, his was far more rigid. Now I am experimenting with PEX. I heated it to slide over the fittings and then clamped the ends.
Now comes the real question. I put a pressure gauge on the fuel system after the pressure pump in the bottom of the IP. I always thought there was to be 15psi from the in tank pump and 60psi from the IP pump. So I bought a 60psi gauge, thougtht 160psi was a bit overkill. I am only getting 5psi from the intank and 40, at idle, from the IP. If I rev the motor I send the needle around so I am way over 60psi.
What is the correct pressures?
