fuel problems on M816
twright
Rockmart Ga. 30153
My M816 will run as long as I have a electrice fuel pump running. I have taken off the tank valve to make sure if was ok replaced all of the rubber fuel lines check all for air leaks did not find any . If I turn the electrice pump on and start it will run if the electrice pump is not in line will not start. anybody have a idea on this or what to check .
1,168
Have you simply run a line from the IP to a fuel can? That way you can see if your IP will draw fuel. I would bet your valve is leaking air.
If your not careful, that elect pump you are using, will push fuel right past your IP and fill your base full of fuel.
Does your primer pump build pressure and work as it should?
twright
Rockmart Ga. 30153
I will try going from the tank to the IP in the morning or should I go to the fuel filter I have the tool box off so it will not be hard to use a rubber line from the tank.thanks
AEC Retired Tony
1,168
I would try a single new piece of 1/2" rubber fuel line from the IP directly to the tank. Don't let it touch the bottom and suck any crud in. You could just put the hose into a Jerry can on the ground next to the front tire(to do this test).
1,168
How did you check the selector valve for leaks? even if its pressurized and not showing any fuel it can still suck some air.
I think the best way is, the process of elimination.
twright
Rockmart Ga. 30153
area52 I put he electric pump in line be hind the valve from the tank everything else was back like it should be did not see any fuel comeing from any of the lines or the valve.
AEC Retired Tony
jatonka
57
Ephratah, New York
bought 2 818s this summer, 1st one, starts and runs perfect. 2nd one, no start,runs on ether, took off fuel line, put in the tank and it runs. Found multiple air leaks in lines coming to selector valve. replaced all lines, Truck Runs Perfect Now. Air leaks don't work on a Cummins. JT
