Fuel pump went south again
nickd
64
Newport, Delaware
Did some PM yesterday changing the oil and fuel filters. Put everything back together and found the fuel pump was making its normal noise but no fuel was coming to the primary spin on filter drain. Pulled the fuel line from the top of the tank and the pump was running but not pumping fuel. Pulled the pump operating it outside the tank and found the pump was turning the impeller but I think once it was placed in the tank the resistance of the fuel was too great as the impeller may have disconnected itself from the shaft. I did not want to screw with it so I changed out the pump with a replacement unit I had on the shelf and all is well. changing oil with the new spin on filters went well (a lot better than the fuel filter change) I saved the old filters to cut them open to see what lies in them.
Has anyone had any luck dissecting the fuel pump and fixing the impeller?
emmado22
170
Mid Hudson Valley NY
There is no shaft connecting the motor to the pump... It's "connected" by magnets. The best thing to do is find a bad motor with a good pump and swap parts.
