Chinookpilot77
- 1
- 0
- Enterprise, AL
I have read many posts on this topic, but nothing was written specifically on my question.
I did Jatonka fuel system change a week ago, found out I had a bad in-tank (didn't run at all) pump...so I swapped tanks (I had a spare tank) and that pump, while it runs, I dont think it has much flow...but eventually, it does seem to bleed all the air from the supply line from the tank to the filter housing.
However, I have clear lines running from the IP back to the filter housing and I can still still air in the system...but it doesn't seem like any amount of bleeding is getting rid of this air.
Also, the problem manifests itself as I'm running down the road under load, but not during idle. The truck will shudder and die, but after another attempt at bleeding, she'll eventually start again (though it takes much more cranking that it used to)
Any ideas?
Thanks for the help. Pictures of my finished truck coming soon!
Any ideas?
