Fuse block dismantled
top_prop
Suffolk, VA
I took my fuse block apart today to trouble shoot some frustrating electrical issues...
Here are my pics I hope it helps... it helped me to understand how the blocks were wired and what the electrical diagrams were telling me.
First find the two bolts and remove them, then place a flat head in the slot next to them to pry the part bolted the the fire wall away from the face that the fuses slide into.
Next you can test the wires at the back to see if the issue is a feed from the source issue or a contact issue... I used lots of contact cleaner and worked fuses in and out an then used and my test light to pry the contacts closed to fix my electrical issue... at least temporarily.
And look at photo two... I think that is the buzzer but mine has never buzzed!
Hope this helps someone.
idM1028
Somewhere in Nebraska
Yep thats the seatbelt buzzer an the top of the fuse block. Theres another bolt on the other side (in the engine bay) that I always unscrew first just so thats out of the way.
