Ga Deuce owners, soldier B swap?
rmgill
14
Decatur, Ga
Ok, so I'm lacking a soldier B for valve adjustment tasks. The GF is not the type that'll get under the truck, lay in the dirt and turn a prybar to turn the transmission output shaft while I adjust valves. Anyone want to do their valves? You come help me adjust my valve lash, I'll come help adjust your engine valve lash. (no wise guy comments :roll: )
gasser
Ocean Springs, MS
I will be more than happy to help ya .... and when I get my deuce next month, you can help me with mine then.
PM if that's cool - I am available most evenings and weekends.
-graham
1,164
I'll give you a hand if Gasser can't help-I get off work at 1600 in Tucker and am usually available on weekends.
PM me if needed.
devilman96
17
Boca Raton, FL
With the engine kill pulled I used a make shift remote start button on mine hooked to the starter. Use a start button and hook one wire to + and the other to the solenoid where the start button normally hooks up... 2 clips, a button switch and some wire... vala! Set a valve bump it over, set a valve, bump it over...
