Generic batteries for M1009
1 Patriot-of-many
87
Zimmerman MN
After heading to Oreilly's auto parts and having a side post battery put on the counter then two top posts the same size when I said it's not a side post, getting them home to find they're not even close, WHAT GENERIC batteries are the same size to fit in the trays? I don't want to spend $200 on a battery. Close to a $100 is okay.
I used the advanced auto battery from autocraft group 31s farm tractor. It has studs so I added the thread on termials . Battery with coupon code p20 was 83.00 and termials were 5.00.
Battery has 1185 cranking amps/ 950 cold cranking amps
1 Patriot-of-many
87
Zimmerman MN
Thanks. Mine has stud type cables so that works even better. That's pretty rasonable price for that much CCA! Well i returned the two batteries that weren't even close. They matched up a set part# 31-5 on the top of the batteries, a little over $100 a battery 950CCA top posts.
Bairrfhionn82
New Brighton,MN
I have Advanced Auto Grp 31 farm & truck batteries $100 a piece 1185 cranking amps and 950 cca with 195 min reserve been in the Beast for over a year starts every time. I had the red top optima in my unmarked Impala, I used to leave the computer on for a couple of hrs at a time with the engine off never failed to start in the Florida heat.My Saab has it now and it starts everytime here in MN.:smile:
tie6044
51
Blaine, MN
I go with the Interstate blems also, I've bought dozens of them for deuces and had good luck with them.
