WARWAG
- 24
- 38
Does anyone know how often the Glow plugs should be changed out?
I would say it is worth the trouble because if you don't you have to grind the gp's down to fit. I payed a shop to change my plugs and the connectors the first time. It cost me $112. I have no intention of ever using Wellman again so it was worth it to me.On the AC60Gs do you have to change out the connectors?
I had the same thought. Also does it matter if you stay with 24v or got to 12V?Just to be clear here... Can I directly change over to the ac60g'S without any other mods? If i understand correctly they burn a different temp than the wellmans. Also, I would prefer them to be compatible with the stock relay and controller card.
Stock glow plugs are 12V. AC60G are 12V too so it shouldn't matter with regard to voltage.I had the same thought. Also does it matter if you stay with 24v or got to 12V?
Ok thanks I was looking to pickup the Quick Heat glow plugs from kennedydiesel.com but was concerened when I say 12volt on them.Stock glow plugs are 12V. AC60G are 12V too so it shouldn't matter with regard to voltage.
Note that the 24V is run through a big resistor behind the air filter housing to bring it down to 12V before it gets to the glow plugs. This, instead of running 12V directly off of one battery, is so you can get properly jumped from the 24V NATO slave cable recepticle.
I was referring to the setup I've seen in several posts such as this one.You CAN'T run it directly from the battery as connected. You will get 24 volts, if I understand your question. If you run from the terminal block you only get 12 volts. If you are wanting to run from one battery you have to ensure that you are only getting 12 volts, not the combined 24.
I have gotten picky, I mostly buy the Kennedy diesel ones. Anti-seize is nice in small amounts , otherwise it affects the heat transfer to the block to allow uniform bleed off.
