Glow Plug Testing Device
rmesgt
274
Grove, Oklahoma
Because I had the parts and because it was too wet (raining) to do anything outside, I built a Glow Plug Testing Unit. I will probably never need to use again, but it worked well to test the glow plugs on my M1009.
cucvmule
collector of stuff
1,171
604
Crystal City Mo
Neat idea, what is your power supply?
I use my battery charger and hook the plug up for a second.
And if you own a 6.2 that will come in handy.
rmesgt
274
Grove, Oklahoma
It was designed to use a battery charger but I haven't tried that yet. I tested my GPs with it connected to a automotive battery that was on my bench. I took a GP to my local hardware store and tested different nuts until I found a 10mm that fit. I bought two and welded them to the holes I drilled in the angle iron. It is difficult to see, but I put a flattened cable lug on one of the bolts holding the angle to the board. That is my grounding point. The red wire connects to the positive (+) terminal.
