glow plugs
rizzo
9
Port Huron, MI
how do u test to see which ones are bad? I thought that I had read it once, but cannot find it now.
thanks in advance
1,827
Either an amp clamp to check current draw or the backwoods method, unplug the glowplug, take a wire direct from the batt and touch the blade of the glowplug. If its drawing juice, you will see a small arc when connected.
mangus580
284
Western NY
use a test light. unhook the gP wire, clip test light clip on + Side of battery, touch tip to GP terminal. If it lights, its good.
