Gov. rebuild M35A3 from a M35A2
Billy Bobbed
13
Terre Haute,Indiana
Original built 1980 as M35A2 with 19,993 original miles
Rebuilt 1995 M35A3 by US Gov issued to the WV ARNG
I seen this in a listing,did they do this.:shock:
emmado22
154
Mid Hudson Valley NY
They stripped them down, and used selected parts to build an A3.. There is actually alot in common with the A2's parts wise when looking at the whole truck.
jasonjc
291
Gravette Ar.
I still don't see why it takes 2-3 too make one?!?!? New eng, new trans,new tires and wheels, axles are new or reworked? All they need is the frame, bed and cab. It's not like its longer or 4 door or a 12x12 or any thing like that.:roll::roll:
Maybe they rebuilt 1 and sold 2 under the table??:-|
emmado22
154
Maybe truck A has a bent frame, but truck B has good axles.. They would basically strip the trucks down to frame rails, and save the good parts they would reuse for the A3's.
Billy Bobbed
13
Terre Haute,Indiana
That is are tax money at work.SPEND,SPEND,SPEND.
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Doesn't have anything to do with overspending, it actually saved money. How many trucks have really good sheetmetal? That was the problem and why it took 2-3 trucks to make an A3.
Silverback
Cleveland Tn
Actually 3 serviceable trucks were sent to AM General to make 2 A3's. Best parts were used to rebuild with, except where new was specified. It was supposed to extend the service life of the trucks at a lower cost per unit than purchasing a complete new truck, didn't quite work out that way as the CTIS was problematic, the trucks actually required more maintenance, had to be jump started if the batteries were low or dead and wouldn't run as fast as an A2. I'm not dissing the A3, I'm just aware of their unique place in the MV world, if an A3 was a girl, she would be described as having a great personality. Dan.
markmontana
Mesquite, NV/Layton, UT
The two to one ratio came about from the large numbers- they took a supply of 6800 A2 trucks and built 3000 A3's. (I'm just making the numbers up- but fill in the correct numbers and the ratio works.)
They didn't pull two trucks out of the line and build yours.:lol: But the soul of the trucks live on...
renovate7
Florida
Well there is one thing I don't understand. My serial # is stamped on the frame under the front left fender. I don't see any evidence there was ever a previous # there. Does this mean this A3 started with a new frame? Do any of you with an A3 see any evidence of a previous # stamped on your frame?
