- 365
- 16
- 18
- Orlando, Fl
In the process of tracing an intermittent problem with the head lights. At times, hi and lo beams work, other times only the low beam. I replaced a very crusty-looking dimmer switch that at times would stick. still have the problem.
I have the TM 9-2320-361-20 showing how to check the lighting system with a VOM meter, and also how to check voltage at the dimmer and main light harness.
My thinking is I have a bad ground. How many places are there on the truck I can check for proper ground? I am not up-to-speed on reading wiring schematics.
Thanks for your help!
