Guage is showing Yellow
prattcobra
Fowlerville mi
My 813 batterys are good.
Guage is showing yellow now.
Cant seem to get the generator to move on the voltage. What is the best way to test and adjust?
Where is the regulator located?
doghead
4 Star General /Moderator
1,189
NY
meter, meeter, meater, meet her, meat her....
doghead
1,189
NY
Measure each battery individually to see if one may be bad.
Then,
Measure voltage with truck off, then running. it should be higher when running.
If there is no increase while running, you probably have an alternator issue.
If it increases but not high enough(28 volts), remove the 1/4' Allen plug on the alternator, and use a small flat blade screwdriver to adjust the max output voltage(to 28.
This procedure should be in the -20 or -34 Tm also.
doghead
1,189
NY
Here's the correct TM number.
gimpyrobb
dumpsterlandingfromorbit!
27,787
777
Cincy Ohio
So according to that, we should be able to find 100amp alts for our trucks that are simple bolt in units? COOL!
armytruck63
10
Morro Bay, CA
Try monitoring with a digital multimeter when adjusting. First of all, you can see it while you are making adjustments, and it is more accurate than the gage in the dash.
If making adjustments really doesn't change anything, then it is time to either get your alternator rebuilt, or time for a new one.
prattcobra
Fowlerville mi
ok. I put another generator on the truck and now I am showing in the green :) when I first put it on it did not show voltage gaining right away. Then after a few minutes it showed a gain. Does the control box have anything to do with this?
doghead
1,189
NY
I have had a couple trucks that have done that. I have never had them not work. Just takes a few seconds to see the gauge change. I just lived with it.
