Hardtop Leaks like its not there.......
TACTICAL6
Newark, Ohio
Don't know about you all, but my hard top has leaked since I got the truck. All the seals take on water. The hardtop is starting to rot away. So it was a PITA, but with the help of my boy, I did a little resto. I removed all the rust, repainted and replaced all the insulation. I finally found a good use for the old PT/sleeping mat. It makes great insulation for the cab. The old seals were still good, I just gooped the heck out of them with silicone. Hope you enjoy the pics.
Flyingvan911
158
Kansas City, MO
That's my plan also. Mine has surface rust but doesn't seem to leak through the seals. Looks like you did a great job. I also need to pop the dent out of the top.
Flyingvan911
158
Kansas City, MO
I think the insulation in my top had mold in it. When I got the truck and for a little while after, my throat would hurt after driving for a little bit. I sprayed Lysol spray onto every surface and into every nook and cranny several times and now I don't have any trouble. I'm going to look to see if there's insulation I can use that won't mold.
1,141
Very nice. Thanks for sharing.
kennys@wi.rr.com
23
Waukesha, WI
I am planning on removing my hard top tonight. Mine looks like swiss cheese so I am hoping I can salvage it. Thanks for the ideas on insulation and I like the light in there.
TACTICAL6
Newark, Ohio
It is heavy!! It took me and three teenage boys to get it down. Two adults could probably manage it though. I put it back on one piece at a time. You might take it off that way if its just you. thanks for the comments, Good luck.
