Harmonic Balancer Part #
79f250guy
Macedon NY
Hi all so I have a quick question as I've see two different numbers for the harmonic balancer for my HMMWV. I have a '92 with a 6.2L. The part numbers I have are 14022671 and 10154688 do you know which one I need for the 6.2? Thank you in advance for your help. Also do you happen to have the front main seal number as I might as well replace it while I'm here. I haven't looked at the balancer to deep yet but I seem to have a bad engine vibration at idle and a bit above so I'm assuming the balancer is part of it.
Thanks ,
Matt
KRedd
Germany
8 pafzz 2805011497859 7x677 14022671 damper assembly,tor 6.2 liter...... 1
uoc:avy,a11,a13,a14,a15,a20,a24,a25,
a26,a27,b16,b17,b18,hvy,h11,h13,h14,
h15,h16,h17,h18,h20,h21,h24,h25,h26,
h27,h28,mmm
8 pafzz 2815014112138 7x677 10154688 dampener,vibration, 6.5 liter...... 1
79f250guy
Macedon NY
I don't know why I didn't see that on the TM's. Somehow I didn't think to search the part number on there. Brain must have been out to lunch. But thank you!
79f250guy
Macedon NY
The obvious question: What is different between those two - other than the static timing mark, maybe?
Very true of course the local parts store has the one for the 6.5 but not the 6.2 I'll have them pull both when I get one to see the difference. My balancer doesn't look to bad actually any other obvious cause of engine vibrations it seems to run good but the whole truck rattles pretty good. I don't know how much rattle is considered "normal" since this is my first m998
