Harris modified H-250 handsets
papakb
1,194
San Jose, Ca
Does anyone on the forum know what Harris does to the H-250 to make it into their "modified" version? Is it merely removing the metal components around the PTT switch to reduce the chance of shock?
Wire Fox
161
Indianapolis, Indiana
At the very least, I know the connector is different. It has a black, more easily oriented connector, instead of the standard U-229.
I own both, so I'll see about making some comparisons.
Sent from my Nokia 6.1 using Tapatalk
86humv
538
Texas
I just found one with a volume control on it.
Also...an earbud connector.
papakb
1,194
San Jose, Ca
That connector style has been around for quite a while now so it looks like the only real difference is the bezel around the PTT switch that eliminates the metal plate and the 2 attaching screws. I love the "specially designed for use with the Falcon I, II, and III radio systems" comment.
Wire Fox
161
Found a little more info! I've attached this Marine instruction course manual covering some radio use. In the component list of the PRC-117F, it mentions a modified H-250, which "has been manufactured to use no metallic parts to reduce the risk of electric shock." I believe in other documents it had showed that the whole Falcon II/III family used the same modified H-250, so this should then leave us our answer.View attachment B180233 - B230387 Communications Equipment Practical Application I - II.pdf
