Has anyone built a turbo setup from one of those cheap ebay turbos?
kenz5380
Denver, CO
These turbos are cheap as heck. Has anyone built a setup for their CUCV with one of these things? What would you all think about trying to do just that? They go for only $180 new with a one year warranty.
T3 T4 Turbo with Internal Wastegate
Inlet 3" Outlet 2" Bearing Wet Floating Bearings Oil Inlet 1/8 NPT Oil Inlet Flange Standard T3/T4 Flange Swaps Great WHP on B Series Swaps Working Pressure 5~25 PSI Compressor .60 A/R Compressor Turbine .63 A/R Turbine Hot Side 2.5" v-band Fits T3 and T3/T4 Manifolds
Part #:ETD-TRB-T3T4-V
Above Pictured is Actual Products in this auction
colt45727
St. Pete, Florida
The only ones I have seen on here are basically all the 6.5 parts from craigs, ebay, etc that are put together and work pretty well.
This turbo maybe a different alternative.
Warthog
240
OKC, OK
You need to download your pictures to your PC and then post them here.
The links you posted will disappear and make the thread useless.
Please read the forum rules.
kenz5380
Denver, CO
You really only need to read the specs of the turbo, the pics are pretty much just like any other turbo you've ever seen.
