Dagboy1
- 0
- 0
- Hudson, WI
I acquired a gama goat a few months ago and have been slowly bringing it back to life. The problem at hand deals with the right head light. It worked initially with the original head light bulb, but it soon smoked out. I bought a new one and it smoked out in seconds. I then did some research on this site, reading many forums, as well as talking to people who seem to know a thing or two about military trucks and 24v systems. Everyone points to a bad ground. So, i just bought a third bulb, but before plunging it in, I put a volt meter on the high beam and low beam power leads. I got 24v. I plugged in the new bulb into the high/low, but left the ground unplugged. I then ran alligator clamps straight from the ground at the battery to the ground wire of the bulb to ensure a perfect ground. I flipped on the lights and the bulb began to smoke inside. I shut it off immediately. I tried the high beam, same thing. This is where it gets really weird... I then unplugged the ground all together. tried the lights. They came on, but started to smoke. I quickly turned them off. Wiggled some wires, tightened a ground wire for the left head light (grasping at straws) and tried again with the ground unplugged. No light. Hooked up the ground to the battery again. Turn lights on. More smoke. Sorry if this is hard to follow, having trouble following it myself. If anyone could shed some light on this it would be greatly appreciated.
