Heart sinewave inverters
sermis
17
Temple, TX
I have a Heart sinewave HF24-2500XC inverter. 80-2512-24
The overload light is on when I connect the power and there is no AC output power.
Any ideas on what could be wrong with it?
ARMYMAN30YearsPlus
Parkville, MD
I would think that it might have been hooked up in reverse polarity and a protective diode blew but I would only be guessing without seeing it. If you can open it look for a diode in the feed circuit and see if it is toasty
ARMYMAN30YearsPlus
Parkville, MD
I have been thinking about this all night and since I had to be up for a 0100 to 0300 VTC with DA I thought I would say that it might also be that it got an overload and kicked an internal breaker or fuse or the breaker is bad.
tjcouch
Tampa, FL
It turns DC to AC, presumably in this case 24v DC to 120v AC . . . .Many neat applications . . . . like running a concert level sound system playing military marches in a parade, or powering a blenders for post trail ride margaritas . . . at least that is what mine is used for.
OPCOM
29
Dallas, Texas
see if there is a short across the AC output. This may not be a simple thing, but try disconnecting the output of the board from the ac receptacle. and check it, and check the board. also look for an MOV metal oxide varistor that might have been overheated and shorted. could be almost anything. What method is use to measure the output current? Be sure it is off for this because the inverter can store a wallop and if one of the output stage devices is shorted, you could get a bang out of it.
