- 34,010
- 1,824
- 113
- GA Mountains
Here's a thought for you Wallew and follow me for a sec since your deuce isn't in the front yard yet. Do the DR thing and remove your spare and install a second tank just like the one on the right. 5 ton tractors and dumps have a similar system with a transfer pump. DR used a crossover tube to keep the tanks equalized. The deuce has an area just begging to be used for storage but I've never seen anyone use it. The 800 series trucks with ISO beds found the spot but use it for storing the removable bed sides. On the back of the deuce where the trailer plug is, lok under and behind that panel. The area between the rails on the bed is wide open all the way to the front. One could fabricate a tray out of angle iron and put it on rollers and tracks and slide it out probably 8 or 10 ft. You could sheet metal it or just attach smaller removeable boxes to it. A door can be fashioned and locked when it's closed. This is perfect, securable, hidden free storage space.
