Heater core sources?
jholler
Jonesboro, AR
Does onyone know of a source for COPPER heater cores for the 1009? Everything I find online is aluminum, (even the copper one in the picture on the NAPA site...I called and asked.) and the radiator shop can't even recore copper cause he can't order it either. I would rather not use the chinese aluminum if possible...
135gmc
St Paul/MN
There are many of the hot water heater kits that were used on darn near any military vehicle floating around. The adapters changed from vehicle to vehicle, but the basis heater stayed the same. Get a core from one of these, and adapt it. You can probably find the basis heater module at MV flea markets at a reasonable price.
blackhueys
-11
mn
well tell ya what I had to do. first aluminum one sucks! I went to my local radiator shop and he could not get one but he had a NOS core setup for an A/C truck he unsoldered my old cap with the tubes and replaced it onto the A/C core after taking the A/C cap off works great not cheap though around 100 bucks but it is factory gm core. If you send me a pm I can send you the shops info he says he has a couple left that he could do this with. hope this helps
DrJekl
Clarksville, TN
I replaced one in my M1009 with one from Advance and it looked like copper to me. If it was not copper then I am not sure what it was made of but it was not aluminum for sure. Made in Mexico.
blackhueys
-11
mn
Should be able to as all the A/C truck ones now days still seem to be copper brass
acesneights1
23
20
CT
I wen through this last year. The alum ones are junk. I used to have awesome heat until I put that POS in. I took my old one to a rad shop and had it recored and put ti back in. That is the only way. They are no longer available in copper. Recore your old one. BTW my heat works awesome again.
hilber
S. of Elberton, GA
Mine is leaking also. I was wondering whre to get one and so I appreciate all the good resposnes to the OP above. Helped me out. I DID A SEARCH:jumpin:and found this. LOL
