Heater
Brutusdog
Louisville, KY
The heat seems to have gone out in my M1009. It worked fine last year and early this spring. Is there a "usual" problem that I should look for first? The blower blows, the air is just cool/cold. Thanks
JAsher45
Redfield, Iowa
i would imagine that your heater core is plugged. start small and work up. check your coolant level... you could be air locked in the heater core . remove the cap and let idle for 15-20 mins. T-stats are cheap. check there before changin out the heater core to inspect it...
twright
Rockmart Ga. 30153
IF the truck is not runiing hot it is not the thermostat. When you said it does not work no blower or not blowing hot? the heater on these trucks are the same as the regular chevy trucks.
AEC Retired Tony
BIG_RED
Winnipeg, Manitoba
If it's low on coolant, hardly any goes through the heater core. Then the heat is pretty unnoticable. Had that happen to me every 2 weeks when my rad leaked. I have all new hoses, new t-stat, and a new heater core. (the last owner put in the heater core - it's even aluminum. I thought that was cool. I would've grabbed a used one at the wrecker). I agree, I'd try cheapest fix first. Good luck!
