HEI Distributor conversion
Hal_VT
Vermont
There are several HEI (GM) distributor conversions for the Dodge 318 engine for sale from various places.
Has anyone used one in an M880? That is a huge distributor cap, compared to the stock one, and I am wondering whether it would fit without modifying the firewall.
I am sick of fighting with the stock ignition, and the associated rotting wiring. The conversions require just a hot wire from the switch and done. This is a working truck, and it should be working, not getting worked on.
N1265
Fremont, Ohio
The bigger distribuitor cap units will not fit without modifying the firewall. I did however do the HEI conversion with a smaller unit from Skip White with good results. ( have since had to replace the ignition modual x2 ) and went a step further the last time by locating the modual by the brake booster and using a standard GM one to make it easier to replace .
I have a video on Youtube under N1265 if you want to see my original install.
Hal_VT
Vermont
Finally got my act together last winter and made the conversion, what a difference. Used the info from your YouTube video, and it went easily and worked instantly after installation.
Just now looking at my old posts and realized I never reported back.
