Help with 24V Starter
testpilot94539
Folks,
A while back I got my first M-1009 CUCV (an 86)and it had a bad isolated ground alternator. After searching the forum I came up with a WIlson part number and was able to obtain the alternator at Napa Auto Parts.
Now I have a 2nd M-1009 CUCV, an 85. I have been fixing it up but the starter went out today. As I recall, somewhere here or in a site linked from here someone had posted pics of the part numbers for both the isolated ground alternator and the 24V starter. Both of these parts were Wilson parts. Does anyone remember where?
If not, can anyone reference a source/part number? I have the Roscommon instructions to convert the system to 12V, but do not have time now, so I would simply like to obtain and replace the current 24V starter.
Any other ideas/links/references are welcome.
Thanks,
Fritz
acetomatoco
Don't know what Wilson is, but any good starter/alternator shop will isolate the ground on a civvy alt for about 30 bux...and fix your starter too... ACE
testpilot94539
Ace,
Wilson is a Canadian parts supplier of alternators and starters. They have a lot of parts for older and specialty vehicles, and they sell through Napa.
Magnus,
Thanks for that link. They have exactly what you said, and I ordered a couple, as well as a couple of fuel filters. Im going to try and find the part number for the Wilson part, if one exists,and when I do I'll post it.
Fritz
testpilot94539
Folks,
With a little research, I found the Wilson P/N for the 24V starter: Its 91-01-4376. I decided to convert the vehicle to 12V using the Roscommon conversion listed on this site and it is fairly easy to do. I have ordered a couple of starters from OD Iron since I have a second CUCV thats 24V. (and plan to leave it that way for a time)
Fritz
