Help with HEMTT
m376x6
Colorado
I hope this is the correct category of truck. I have a part that has been buried in my parts bins for a couple of years. It is NOS and I believe by the part number it is for the HEMTT family of trucks. The part number is 85570-06-24P. Before I list it on ebay I would really like to know what it is for and what the general name is. Would one of you folks who are familiar with these trucks lend a hand. Thanks in advance.
m376x6
Colorado
The small bag has some o-rings, plstic plugs, and a rod threaded atboth ends. I'll include a picture of the backside . It has some sort of threaded stub piece I assume the rod threads into and the solenoid has the actuator rotate the stub shaft to some degree. Thanks
Gringeltaube reply and pic sent through email per your PM. Thanks for any help.
Stalwart
33
Redmond, WA
Looks like a control valve, both manual and electric, but the number isn't in any of my HEMTT manuals.
Now, if you had the NSN number I might be able to help further.
mkcoen
380
Spring Branch, TX
I'll have to dig around in my "parts bin" because I believe I have a similar item. With luck it'll still have the NSN on the packaging.
m376x6
Colorado
I found the NSN: 4820-01-193-1762 Gringle made a reference to a manually and electrically operated control valve for a crane. I wonder what series number of truck this applies to. I've seen pictures of all kinds of HEMTTs. Thanks everyone.
Stalwart
33
Redmond, WA
OK, my book has the part number as: 85570-06, it is the valve assembly for the M977 and M985 to control the rear mounted crane. I could probably use one (or more) as a spares depending upon price.
m376x6
Colorado
Good call, to the OP, I ask my question....M376x6.
I saw a picture of a model of an M37 in 6X6 configuration, in a book written by Zenthmeyer, many many years ago and built this truck based on that picture. I had discovered a way to mount a new model M37 transmission to a Mopar V8 and dropped in a 360 V8 wth engine driven air compressor and power steering.
