help with trailer plug
jwentz57
Etters PA.
I need to reconnect the wires to where the trailer plugs into on the back of the deuce and a half. some one cut off the wires and made a mess of it. have enough wire on it to reconnect it but have no idea what connect to what
jwentz57
Etters PA.
OK thanks I will see if this will help. just have to find out what wire is what on the truck. then connect the two together
steelandcanvas
87
Southwestern Idaho
If you have a meter or test-light that will really be a time-saver. When making your connections, I would use some heat shrink tubing and a nice butt-splice. This will make for a trouble free connection for years.
KsM715
142
St George Ks
This might help.
xm757%20trailer%20connector.jpg This pic is looking into the trailer cable.
The drawing in the lower left is what you would see if you looked into the "plug"on the the back of the truck.
