Hi newbie from Massachusetts 1986 1028
tony42692001
Wilbraham,MA
Hi I have just found this site and I am relieved. I inherited a 1986 1028 CUCV and let it sit for a year. I placed a 6 inch lift from Ruff Country on and did crossover steering from Ord. Also did a block heater because it gets really cold here. Ripped rubber floor out and replaced floors. It currently sits on BFG Military OZ tires on 12 bolt beadlock (recentered) rims.
I have two problems. The first is the rear brakes do not work and are currently disconnected at proportioning valve. When I hook them up the breaks grab and lock causing truck to go out of control. Has original monster drums.
The second is that I received 39.5 Ground Hawg tires and was thinking a 4inch shackle flip in rear but I am not sure what to do up front. Rear lift is 4 inch leafs with 2inch blocks and front is 6 inch leaf packs. I was thinking 4inch ORD flip in back and take out blocks but front is a mystery.
Any help or suggestions I would appreciate. I am the only person who owns one of these truck in my area so I am on my own. Thanks Justin
Warthog
240
OKC, OK
Welcome to the site.
Alot of CUCV owners here.
Have you download the free technical manuals? They are listed in the Tech Manual section. You want the TM 9-2320-289-xx series. You also want the parts manuals that have diagrams of all the parts on the truck along with GM part numbers. The pictures are nice in that they help me "see" how stuff goes together.
Read through the troubleshooting section to help with the brake issue. Driving with disconnected brakes is a bad idea.
First thought on the rear brakes is the weight proportional valve at the rear axle. It may be bad.
