gmjunky87
- 1
- 8
- halifax, pa
one day I switched my high beams on and went to turn them off and lever moved but no "click" I've searched and can't really find anything on here related to this problem. I'm not sure if something is broken at the stalk or at the actual switch. I usually run with my high beams on at night because the low beams suck but I usually like to run with my low beams on in the daylight. I really don't want to pull the steering column apart
