HMMWV Trailering
rcb
pittsburgh, pa.
MVers: When my EUC clears and I schedule pick up for my HMMWV, I was wondering how fellow MVers
have been trailering them. I see pictures of a good many of them sitting on regular car trailers
but I'm curious how they are loaded. My car trailer is 83 1/4 " between fenders and my construction
trailer is about the same. I believe the distance between the HMMWV outside of the tires is just a bit
wider. Are you just driving and forcing the vehicle between the fenders or driving up on one fender ??
Thanks...
Bob
Sintorion
14
Fla
Mine is 85" sidewall to sidewall. My trailer was 83. I drove down the middle. The fenders were solid so the tires squeezed between them. They were a touch bowed when I was done. I was thinking about stacking some 2x6s to drive over.
jeffy777
VA
My measurements:
The outside edges of the HMMWV is 85 inches(not including mirrors). The standard military wheels are however a little over 82 inches edge to edge. You should be fine although you need to be very good at driving up on the trailer.
The TM -10 says:
Page 1-30 of the Operations Manual (TM 9-2320-280-10) says 85 inches.
Jeff
Sintorion
14
Fla
I think the 82" wheel measurement is probably accurate, but it doesn't taken tire sidewall sag into consideration. The sidewalls of the tires bulge out which is where you easily pick up the extra 1.5" x 2. It is really a matter of inches. As long as your wheels are above the sidewalls and your air pressure is around 20, you should be able to squeeze through. Just be careful if you do bend the fenders, that they don't touch your trailer tires going down the road. A little rubbing on those and you will be in for a wild ride.
PaFarmer
35
PA
My trailer is 81" between the fenders. I made a set of ramps the shape of the fenders. The HMMWV tires were several inches over the fenders on both sides. 85" is a good estimate. My tires were not fully inflated, so the foot print was wider.
desmodromic
22
New York, New York
Sidewall to sidewall is definitely 85-86". As sintorin and others have said, either lower the air pressure and squeeze it through or build wooden ramps. The only real option for full clearance is a deckover. I recently bought a 102" wide trailer with drive over fenders specifically for my Humvees, but unfortunately it is still only 83" between fenders and the fenders are too wide to drice over both at the same time. :(
My M966 made it on fine, but it still has the 36" RT pizza cutters. I am confident things will get a bit tighter once the 37" MTRs go on.
Good luck with the recovery.
ARYankee
33
Benton, AR
83" of clearance will get you. I had the same questions and concerns when my EUC cleared earlier this month. I rented a trailer with 83" of clearance inside the fenders. The wheels rubbed but it fit. You will need a really good spotter. I was also concerned about the weight but the trailer was rated for 7,000 lbs. Depending on the Humvee configuration, more than likely it weighs a bit under 6,000 lbs.
teteacher101
WI
Thanks...
Bob
I used my car trailer but it has aluminum fenders that are removable. So an electric impact and a wrench, an a fender is off in about a minute.
OLDBEAR1234
50
Irving, Texas
I am curious if you were able to rent from a nation wide rental company or someone locally?
pig9r
KCMO
U haul silver not orange car trailer will work but very tight.
They will not rent if you disclose hmmwv or h1. You will have to say jeep cj5 or something else in their data base. Tow vehicle has to also be rated for the correct gvwr.
Ymmv
The driver‘s side fender fold out on those trailers also which help squeeze through.
Action
1,561
East Tennessee
If anyone gets in an accident hauling a HMMWV with a uhaul trailer, whether their fault or not, I assume there will be some consequences...
I personally would get a flat equipment trailer rated to haul it, with a tow vehicle rated to tow such trailer. Rollback tow trucks used to charge $1 / mile one way.
Coug
4,589
Olympia/WA
One caveat with the Uhaul trailer, what I was informed is the way their insurance works is once everything is in the system (tow vehicle and trailered vehicle) that is what the insurance on the trailer covers. If anything happens to the trailer with a different tow vehicle or different load trailered, then the insurance in the rental contract is null and void, and they can go after you for any damages to the trailer.
Not saying it is true, but it is something I have been told, and it does make some sort of sense. Their system is set up to cover their butts with rentals; i.e. to prevent people who likely don't know how to drive a trailer from being stupid (like trying to tow a heavy car on a trailer behind an old ford ranger with the ball only on the bumper).
Looks like Action beat me to it.
OLDBEAR1234
50
Irving, Texas
Yes, I am looking for a truck and trailer, I have not found one yet. Thanks.
OLDBEAR1234
50
Irving, Texas
Good points for sure.
Action
1,561
East Tennessee
You can't make this stuff up....
<iframe width="754" height="424" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
juanprado
3,076
Metairie/La (N'awlins)
As always ymmv but different Insurance companies and state regs come into play. Your auto policy typically will cover any trailer you tow. Check your policy and State Requirements.
AOR
37
Burtonsville, MD.
I haul all my stuff on a 14k 102” wide deck over trailer no fenders to worry about. The HMMWV is fairly light load at 5200 lbs but with the engine and drivetrain mounted to the passenger side and on an angle and with most of the weight upfront I use my air bags on my ram 2500. I have hauled much heavier loads not needing to use the bags so be prepared for allot of tongue weight
