I've been trouble shooting the horn not working on this 1008 since I got it. Took a while to figure out the Service Light toggle has to be on, pays to read the manuals. I'm to the point now if I jump a wire between two of the terminals where the relay plugs in the horn works. I've got a new relay but the horn button won't make the horn blow. I took the horn contacts apart on the steering wheel and cleaned them. Even tried a jumper wire with this mechanism off, no horn. Will a test light on the third terminal of the relay socket light up if I use the horn button? Any way to tell if I've got connection between the horn button and relay, or if the new relay is bad?View attachment File.PDF
