Horn stuck on, diode problem
dependable
188
Tisbury, Massachusetts
Had a problem with a non-working horn on a GL purchase CUCV today. Fuse had been removed. When I put in fuse, horn stuck on. Removed horn relay. Still the horn was on. I suspected a short in harness, removed electrical tape just above horn relay. There is a diode there, in the horn relay plug. I cut the diode, problem solved. I wonder what other electrical glitches in the CUCVs are caused by failed diodes, which I believe are for radio noise suppression. I checked my civilian 6.2 s and they do not have a diode there. This might tie in to Warthog's excellent posts about wire harness, as he has already located a lot of the diodes.
Bobert
9
Des Moines/ Iowa
I just fixed my horn too. It never worked, I think mine was burnt out. Is the diode you are taking about just looped from the power wire to the outgoing horn wire on the relay?
I couldn't figure out why it was there since it sent 12v all the time to the horn. I wonder if this is the same for all of them.
dieselpony
Stuttgart, Germany
In opposite to lights, wipers etc. the horn is switched with the negative side. When pressing the horn button the circuit is grounded.
I assume the diode is to not cause trouble with military parts like communication or radio equipment. Like the ones at the wiper motor or on the back of Gen 2.
Walter
Sardot1
Northern Arizona
I developed this problem after having electrical issues that turned out to be just two shot batteries. Replaced the batteries and my horn was stuck on. Pulled the fuse to quiet it. That was last year. Finally got around to researching it today and found this thread....Thanks!
The best I could tell, the diode did look fried, so I cut it. The horn quit but it still did not work when I pressed the horn button, just the relay clicked. This is where having a spare truck comes in handy...I swapped the relay out and the problem was fixed. Now I just have to buy a new relay for the other truck!
Seems that I fried both the relay and the diode, or one caused the other to fail.
Sergiopc
Houma, La.
Ok I am having this issue and I have read all of your replys.... Are you all talking about that thing right under the horn???? I cut that out and still not working or if I hook up that thing it just stays on..... I have been looking for other things in line and could not find anything... any one have Pic's of this diode.... Thanks
1,187
Do not cross post.
MarcusOReallyus
819
Virginia
There's a sticky with pictures; just look for it at the top of the forum. The stickies are very helpful. That's why they are there.
