How are these glow plugs?
Braunchitis
Cape Girardeau, MO
I suspect my glow plugs are keeping my truck from starting when it's cold. I have puffs of white smoke from the exhaust, but it won't start without 5 minutes of cranking or starter fluid. And I don't like doing either of those. But, before I spend $90 for plugs, I want to be relatively sure that's what it is (because I'm broke). I've been told you can tell by looking at them if they're good or not. When I bought it in December, the guy said he had put some in recently. I'm not sure what's normal-looking though...so can someone tell me if these are OK or not? Thanks
1,168
You can not tell if they are good by looking at them(you can sometimes tell if they are bad by looking at them). You need to use an OHM meter to test them. If they are 070's I believe they are self limiting(should not burn out or swell), that still does not mean they wont go bad. Very good chance you have other problems with your GP system. A full GP system diagnosis is probably in order.
M1075
Oklahoma City
You might also consider a manual glow plug swtich if your controller is not functioning properly. See the sticky at the top of the CUCV forum.
EO2NMCB
22
DeSoto, MO
Talking the mech's a couple of weeks ago at Ft Lwood mo they stated the glow plugs should ohm out between 1-3 ohm's any thing above or below that and the plugs are bad.
1,168
Re: RE: How are these glow plugs?
mangus580 said:
If you have them out... its really easy to tell if they are good.... put 12v to them, they should get HOT
Danger! If they are not self regulating, you could be injured by putting power to them to test them.
You won't get burned testing them with a VOM.
mangus580
282
Western NY
doghead said:
Danger!
You wont get burned testing them with a VOM.
I didnt say hold them in your hand!!!
I have heard that sometimes you get a good reading with a meter, but they still dont work!
the only TRUE way to know if they are good, is to power them up...
1,168
RE: Re: RE: How are these glow plugs?
Don't believe everything you hear, Mike! :wink:
1,168
Also keep in mind, bad glow plugs are usually the result of another problem. I heard that somewhere! :lol:
Braunchitis
Cape Girardeau, MO
Well crap. I got them out and tested them with the ohm setting on my multimeter (one point on the threads, one on the tip where the wire attaches) and I got nothing.
Except for one...seems it swelled up and won't come out. Does anybody know any way to get it out?
dam88
Loosen the glow plug, clear a clean path towards the neighbors roof and rotate engine.
WARNING:
This could be hazardous to you, your family, the dog, your truck and your good (if they are) relations with your neighbor as it should come out with (if you have good compression) some amount of force!
:D :D :D
