airbornebandsman
- 19
- 18
- Universal City, TX
How in the world do you change the boots on the PTO? the end closest to the PTO will not budge is there something special i have to do to change them out?
Thanks
Thanks
Would you mind elaborating on what finally worked for you and how you would have it done in an easier fashion?well i finally got it, i guess I did it the hard way. Thanks for your help.
I know this is several years old, but I am reading that the boots on the pto could be installed without draining fluids and removing shaft/linkage..?Well I ended up with the old boots tearing. So I used a small screwdriver to dig out the excess from under the lip on the PTO. To put the new ones in was prettyy easy until the end, I had to use a screwdriver to gently get the last bit of the part of the boot that goes under the lip under it. It wasn't to hard but I din't really know what I was doing (of course I never really do anyways) until I got the 1st one in. Sorry if this was vague I am not very good with explanations.
Yes, but you must be extremely careful or you will tear them.I know this is several years old, but I am reading that the boots on the pto could be installed without draining fluids and removing shaft/linkage..?
