How much paint and which color for M998
cucvegas
14
NW Arkansas
How much paint should I buy to paint a humvee inside and out? Just doing solid green with black bumpers, etc.
Rapcoparts.com has GCI for $40/gal.
Which green color is recommended: CARC substitute or current issue lusterless Olive Drab, etc. ?
Sintorion
14
Fla
I went with Sherwin Williams CARC. It was about $100 for a gallon and a gallon was enough for an over spray inside and out with a little left over. The color match was perfect as was the finish. I looked at rapcoparts and even Behr as some have used. The only justification I could find in going non oem was cost and for $60 in the big scheme of things it wasn't worth it. I am glad I did because I saw one painted with Behr and it just didn't look right. The finish was off and the color wasn't perfect.
cucvegas
14
NW Arkansas
Thanks.
which specific color did you use, and did you have to mix the paint with thinner or hardener?
Was one coat enough, and did you prime it first?
Stonewall
Peoria, IL
You can check out all these answers in the paint and body forum on this site. There are sticky threads concerning paint codes, and many, many threads regarding paint type and quantity and prep.
