How much paint for M1009?
BKinzey
Hollywood, CA
I'm going to be painting the exterior body of my M1009 and I have no idea How much paint to get. Hopefully a gallon will be more than enough? So a gallon of primer & a gallon of paint?
Thanks
Armada
Buick City, MI
Definately get 2 gals primer, and 2 of color if you're doing in and out. Depending on the kind of job you want, you'll want to prime, block sand, prime again, and 2 coats of paint. You'll have enough to do inside of top, under hood, front and backside of bumpers, everything. What kind of paint are you using? I can only comment on Gillespie 24087. I would recommend using hardener with it, if that's what you're using.
BKinzey
Hollywood, CA
It's just the exterior body. I have other plans for the frame, undercarriage, and interior.
How about the cap? Since it's fiberglass do I need to primer it as well?
As to the paint itself I'm not sure but I do plan to stay away from CARC as I've read about exposure & enviromental concerns. Since this will be my first attempt of painting with more than a rattle can I should stick to basics. Of course I will be using a mask, gloves & protective clothing.
