Hub Screws
I keep having issues keeping the screws (part number 3 in the picture) in the from hub covers from backing out. I have lost a total of 3 of them (2 on the left front, 1 on the right). I don't know if this is indicative of a problem, or maybe I am not putting enough ass behind it when i tighten them down. Im considering putting some blue loc tight on them....BUT i want to be able to easily service the bearings. Is this a common problem, or am I just being a nancy when I tighten these screws down? Would yall recommend any type of thread sealer?
Also, can I buy these screw anywhere other then the stealership? I haven't actually BEEN to the parts stores around here, but my searches online with the GM part numbers havent turned up any results at the big stores, i.e oreilly, autozone, napa, etc etc
Westech
CPL
6,104
212
cow farts, Wisconsin
I have got some blots that fit from ACE and True-value hardware. I do put a dab of RED on my bolts but blue will work too.
You can order packs of 12 bolts for under 8 bucks. Google it.
K9Vic
Fort Worth, TX
The parts guy at O'Reilly's told me one time they do sell the bolts individually, just go to any parts store and ask for them. I had all of them missing on my M1009 on one side when I bought it, but I just replaced the whole hubs over just adding the missing bolts. The only thing holding the hub on was silicon, scary as I was off-road before and lucky it did not pop out.
http://www.steelsoldiers.com/cucv/59079-m1009-lockout-hub-bolt-question-not-allen-bolt.html
DokWatson
Wasilla, Alaska
Depending on the manufacturer of your hubs, 'rebuild' kits are available. They include all new snap rings, o-rings, and screws. My mile marker instructions recommended loctite on the screws.
wikallen
IA
Just use locktite, something in the 222 range (purple) but the blue will work, just harder loosen.
