Humvee tail light question
kcimb
212
Fort Worth, Texas
Do the tail light units contain the brake and turn signals?
I'm needing to retrofit turn and brake lights onto another vehicle that doesn't have them and the humvee LED rear assemblies look like the ticket.
papakb
1,194
San Jose, Ca
I'm not sure what your asking here. The front and rear lights are called composite lamps and have independent bulbs for each function internally. If your asking about the red and yellow lens assemblies, no, they are not interchangeable.kurt
vitamink
Indianapolis, IN
I'm not sure what you're asking either.
What do you want to put them on? Is it 24v? If not there are still some options for you that are 12v. You may have issues with the LED's not tripping the relay as they don't draw much power or blinking to fast (like you have a bulb out). You may need either an in line resistor or different flasher.
All the above are just random thoughts, as i'm not sure what you're attempting to do or do it to.
