Csm Davis
- 403
- 83
- Hattiesburg, Mississippi
what do they have on the m35a3? copy that system would seem the way to go. just my two bits
Yes i have measured a few things, but i need to actually put a represented item with the actually size of the pump in there though.Have you looked at where you're going to mount the pump and belt routing? A PTO driven pump would cost more if you bought a new pump but used pumps can be found very reasonable that are under old dump trucks. I'm going to run a pump off a t-case PTO to power my dump. I got the pump with the hoist that came from a old dump truck.
Im not sure how the a3's are setup, any one?what do they have on the m35a3? copy that system would seem the way to go. just my two bits
Can't argue with you on the ease of operation with hyd. I was just letting you know your options.i really want a hydraulic winch for the finese and one man operating.
isnt the stock duece winch only 10k pounds?
No, the maximum psi is due to the winch itself. Stall load is based on the amount of psi to the winch. So a 9000lbs winch will stall at 1450psi at about 9100lbs because that is all a typical power steering pump can supply. Now if it was to get more psi than 1500, 2 things would happen, you could brake the winch hosing and more then 1500lbs would blow the seals in the motor. Now if you pull less then rated load on this winch you would never see his happen to your winch, but if your load keeps going high than the rated load you could end up hurting the winch and the motor and would not be covered by warranty.
If there is more then 3.5gpm, the winch will run faster. But the out winches at supplied with a jci6 size hose, which means if you pump more then 5gpm through it your fluid with start to get really hot. With all hydraulic fluid, they work best if you can keep It to as close to room temp as possible.
The valve we supple with the winch can work up to a maximum of 7gpm, go higher then that and you could destroy the valve, but the motor can take up to 15gpm.
Remember this, psi = stall load GPM = line speed.
Kenrick Perkins
Warranty Dept.
954-782-0604
KENRICK@MILEMARKER.COM
i asked what the flow would be
At 1500 psi, you will be drawing 120 amps using our standard 24vdc motor and our largest displacement pump. You would be able to run this continuous for around 4 minutes before the motor should be allowed to cool to ambient temperature. The S3 would be around 15%.
It's a little better at 24vdc, but not much. 2.1-2.5 gpm
What does the stock winch pull for speed at full load?Yes, but 24fpm sounds slow if you are walking, but pulling 9000 or 12000lbs at that speed is dangerous.
