I go get my Deuce tomorrow!!!
progun
Duson, LA
Pretty excited! Got a group of guys, tools, fluids and a to do list. Gonna try to start her up first then do the brake checks. Can't wait and will post pics soon.
progun
Duson, LA
Unfotunately, she's not here. :( I wish. I will need to borrow some tools if that's ok Jim. Will you be home this evening?
Heavysteven
11
Hickory Flat Ga
Progun good luck on your recovery.
I will say change all these items before leave
1. Air Filter easy
2. Spring Vents on axles easy
3. Check belts have replacements
4. Change the radiator cap
5. Check oil (mine was overfilled)
6. Check brake fuild
7. LUBE AIRPACK takes 5 mins to pull off J and squirt air tool oil in there
8. Drain filters in empty water bottle
9. Add 10 gallons new diesel
10. Check tire pressure (all mine were at 5-10)
11. Spray lubricate on controls lines going into Injector pump
If you have any doubt about the brakes it not worth risking your life.
If you have time
1. check axle gear lube oil
2. check trans and transfer case gear oil (need 1/2 drive wrench non rachiting "i can't spell" buy the one at Sears)
3. Grease fittings
4. check for operational lights and horn
If this is your first deuce it will be hard to do all these things quickly.
BE SAFE, every has family and friends on public roads.
Post pictures or movies[thumbzup]
