WARWAG
- 24
- 38
Well this year has not exactly been stellar for me and today was the icing on the cake. We sold my New Truck and picked up the wife a used Jeep to help on the Bills side of things. I told her I would keep my M1028 as my daily driver. She has been great for sure. Today after picking up a diesel filler neck (for second fuel tank install) and cigarette lighter plug at the junk yard I thought life was good. I plug the light in NOT PUSHED DOWN, and started up my truck. I get about 15 feet before the cab starts to fill up with smoke. Smoke is billowing out from under the hood as well. My wife is getting a bit excited right about now. I turn the key off and pull the hood latch. One of the wires of the battery is billowing smoke. My tools are locked in the back shell and I happen to remember the Kuhkri knife on the floor board passenger side. I whip her out and sever the 10 gauge wire thats on fire. Unfortunately she has already melted into the positive caple wire (24 volt) and is still going. I reach in and grab the VERY HOT wire and yank her off of the 24 volt wire. I then pat out the little fire with my burnt hand. Better than loosing the truck. Turns out it was my fault from the very beginning. When I installed my cigarette lighter plug to power my cell phone charger I neglected to install a fuse in the line. DUMB MISTAKE. Today when I plug that USED cigarette lighter plug it made a connection and kept right on charging. The 10 gauge wire can take quite a bit of power. I was able to clean out the burned up wire and tape what was burned through. I made it back home with no further problems.
Lessons learned:
#1 If you have a direct connection to the battery you should have the appropriate size fuse to protect your truck ect.
#2 Not all things cheap at the junk yard are a good deal. (I dont smoke but a cigarette lighter is great for starting fires. Even those you dont want.)
I will get some pics later but so far it doesnt seem to bad. It sure looked a lot worse when there was black melted plastic/rubber and other things starting to burn. After I cleaned those up I felt just a bit better. BUT it stills sucks.
I hope this helps protect someone in the future.
Lessons learned:
