I have air conditioning AND a running M1009!
andytk5
florida
I know this is old but the Nostalgic Air evap box mounts over the M1009 heater box without changing the heater setup?
367
Castalian Springs, TN
Question... as well... Anyway of using a GM A/C control unit instead the one you installed? as i would like to keep my voltmeter on place.. and possiblly split the defroster vents and attach the ac vents to them.. also wonder bout the possiblity in mount compressor on Driver side....
wrex
9
Laveen, Az
Ok, I went to the NAP site and am failing to find a complete kit for $950. Have any part numbers you can reference? Thanks!
andytk5
florida
****, I'd settle just for the part number on that evap box that fits in there so nice! If i can find that then the rest is much easier. I'll try to call NAP tommorow and see if I can get the info on that. I'll post back here if I do.
southdave
ripley, oh/TDY Lordstown,Oh
Kip
I have one in my 1028and another yet to install in the 1009 if I don't set in it a blaze first
I been considering a rear a/c out of suburban.. the under dash 60 thing I was told will not proform as well as i expected... are you considering this kip? I could hook you up with my leftovers from a bunch of civy trucks
andytk5
florida
I was meaning the "in dash" evap box that is in the pictures. What brand/part number is that piece since it fits over the heater box behind the dash.
Barney Fife
Jefferson City, MO
Blackout / service light switch relocation
Here's how I solved the blackout light / service light issue. I recreated and resized the decal design using Microsoft PowerPoint and sent the design to Vista print.com. I used the window decal option to have the new decals created.
It took some finagling but I was able to fit both switches under the main light switch. I had to rotate the main light switch 270 degrees counterclockwise in order to make room for the blackout and service light switches.
The result is that I made room for the air vent while maintaining the overall look original switch location.
