Erik Jenkinson
- 8
- 18
- Metairie, LA
I woke up this morning to find a puddle of very clear (Yellowish) fluid under my m1009. Judging by its color, it seems like unused motor oil. As I looked closer, I began to think maybe I had a leaky brake line, but dont see any obvoius leaks thereabouts. As I looked for the source, I thought it may be a fuel line or the IP, but I dont see any fuel in the valley under my intake. This leak apperars to be coming from the small mounting plate where my engine temp sensor is, as well as the similar small plate on the other side. What strikes me a odd is that this fluid is very clean, while the oil in my crankcase is about as dark as one would suspect. Not cloudy or burnt. No oil in my radiator. The truck behaves pretty normal, no smoke etc. I very recently replaced the rear main and oil pump, maybe 600 miles ago. That little mounting plate was maybe ever so slightly loose, but this leak continues even as the vehicle just sits. It isnt coolant. I dont see a brake line in this area. Anyone ever see this before?
