I've had this 66" Ibis Tek lightbar for nearly 2 years (purchased from a member here, TedG). So last weekend I thought I should do something about it!
I will say it really hurts to drill 1/2" holes in you truck's windshield frame (the lower holes I put in bolt sleeves, but just the 5/16" bolts only on the top). Grade 8 bolts of course!
The passenger window sits more to the right than the driver's, so there is some interference with the support hinge when opening/closing the front window. I wised up and reduced the problem (though sadly not eliminated) by flipping the bolt around and putting the lock washer and nut on the exterior.
