Injector Pump stud nuts...How in the world...
Asmoday
Los Angeles, CA
do I get the nut back on for the driver's side stud on the injector pump?
I was only able to get it off by breaking it loose with a open end wrench and then after using a ample amount of PB Blaster...using the tip of a screwdriver to spin it off by pushing on the edge of the nut.
Once it came off I had to use a magnetic pic up tool to grab it from the engine valley.
Soooo...tips and/or tricks to get it back on? I can't fit my fingers down in there to get the nut back on. Special tool maybe?
Thanks...!
plym49
171
TX USA
Maybe masking tape sticky side out on the end of a screwdriver. Use it to get the nut positioned over the stud and then use something to spin it back on - maybe the flat of a screwdriver to hold the nut down and another to spin it using the flats.
Asmoday
Los Angeles, CA
Really...? Ok...I'll try that. It did not look to me like there was a straight shot to the nut from back there but I will give it a shot.
Thanks...
ryan77
56
Cary IL
Its hard enough with the intake off, 2 times harder with it on, use one of those magnets on the old style antenna thingy u can get at autozone!
rickf
2,199
Pemberton, N.J.
I have done it with the intake on but it has been a long time ago. I do remember using several extensions and a couple were wobble extensions. I don't remember it being all that bad other than laying on top of the engine. Wobble extension are GREAT! I use them all the time even when I don't need the wobble effect. Makes it quicker getting on the nut or bolt.
Rick
P.S. There is a special wrench to get the bottom couple of injector lines.
Asmoday
Los Angeles, CA
Special Tool for Drivers Side IP nut...
I used a special tool to get the nut back on with the intake still in place as shown below...LOL. A very high powered magnet taped to a long flat blade screwdriver. I lubed up the nut with anti-seize and used another thin blade screwdriver to thread it on...:) It was actually a piece of cake.
