Installed New injection pump on 6.2L. Now im having trouble getting it started.
wrench33
Western Kentucky
A new injection pump was installed on a 6.2 L. Timing marks are lined up, and its getting fuel through the lines. I adjusted the TPS just to see if I could get it to turn over. Ive had no luck.
What am I missing?
Thank You.
Benn
1,168
It won't turn over? as in crank over with the starter?
dilvoy
25
San Francisco, Ca.
One of the wire connectors is smooth and one is ribbed so they can be matched to the connections on the injector pump. Maybe you switched them around.
wrench33
Western Kentucky
Its a M1025 Humvee. I replaced the injection pump. I i got it running. Its running really lean, and when under a load cuts out.
I believe its in the throttle position sensor, however I just cant get it figured out and its starting to frustrate me. I appreciate the comments on this thread, Im trying to research the issue now.
If anyone knows what this could be by what I have said on here I would appreciate your input.
Thank you.
nattieleather
134
Cleveland, OH
Air in the lines? Plugged filter? I always try to trouble shoot under the K.I.S.S. method. Keep It Simple Stupid! Like timarr said start with the stupid stuff and work your way up to the hard stuff.
Retiredwarhorses
3,893
Brentwood, Calif
What's the part number to your new injector pump?
what motor and transmission do you have?
unless you have a 4L80E tranny you don't have a TPS....
